Chris,
You are likely right its a phenomenon brought on by the chosen headspeed.
I know this a bit from FBL experience with helis, some units will handle low headspeed and others wont. BeastX does not have the tune ability to get rid of alot of the bad tendencies that arise at much lower headspeed, Bavarian Demon and Spirit handle it well. That being said it looks as though Pixhawk has plenty of tune ability to get it flying well also. I fly my other V3 style Trex 800 with an FL head, not DFC, at 1000 rpm all day long without any issues, save for my sloppy collective management at times. Thats a hard habit to break when your used to 12,000 watt motors with 160-200amp escās that cant be bogged even at 14Ā° of pitch. It brings alot of bad habits to flights when you start flying more scale like, low headspeed aerobatics or UAS work im finding out.
The Blade 700X i have has quite a few headspeeds it just does not like, some of them in the 1600ish range, on the low side it doesent like 1200ish. . In those ranges the heli will ossicilate in a hover and just plain not fly good.
With this Trex 800 stretch im using ive had it in the range it at currently without issue so it makes me question my setup in Pixhawk more than anything?
6 or 1/2 dozen, seeing that you have far more experience with Pixhawk than I and more experience with lower headspeed and scale type flight, i will defer to your advice and bump the headspeed up 50 rpm and check condition.
I dont mean to keep comparing Pixhawk to an FBL as clearly its in a different class of its own, but unfortunalty my only heli experience at this point has been all FBL. I dont think the Kyosho Concept from years ago counts anymore? Plus that dident end well anyways, not enough patience on my part at that time in my lifeā¦
I genuinely appreciate the help and ideas, as yourself and Bill have helped me immensely with this Pixhawk installation!
Tim
