ahmed
(Falcon)
May 28, 2016, 7:18pm
1
Hi all ,
Before two months I try to work with simulation for my plane but always I found problems ,
I try flight gear , Xplane 10 , but they didn’t work well for me ,
Now I want to try it again, and simulate my mission at home .
I heard about HIL and STIL but I didn’t get the Idea it works.
Could any one advice me for the perfect and successful way to simulate with any software .
Regards.
billb
(Bill Bonney)
May 29, 2016, 3:38am
2
Use SITL, it works by simulating HW sensors http://ardupilot.org/dev/docs/sitl-simulator-software-in-the-loop.html#sitl-simulator-software-in-the-loop
It’s better that HIL since you don’t need to have HW to do the testing, which means you can do it much easily.
ahmed
(Falcon)
May 31, 2016, 6:08pm
3
@billb ,
what about if i want to simulate mission using MP and flight gear only ?
With simple steps ,
billb
(Bill Bonney)
June 1, 2016, 4:09am
4
Check then mission planner docs, I personally don’t use it http://ardupilot.org/planner/index.html
ahmed
(Falcon)
June 5, 2016, 6:50pm
5
@billb ,
I went throw the link you post for sitting up the SiTL on windows ,
but I find some misunderstanding in some points .
I get error when I send the command " sim_vehicle.sh -j4 --map "
command not found .
I think the problem is I couldn’t do the step for the .bashrc file .
How to add the line code " export PATH=$PATH:$HOME/ardupilot/Tools/autotest " to the end of the file ?
but it dosen’t work …
any help ?
regards .
billb
(Bill Bonney)
June 5, 2016, 7:07pm
6
I’ve never ran SITL on Windows. I just create a Linux VM and run it in that. (I use OSX for my development work or linux)
