Tarot 3D Gimbal w/ GoPro WIFI/Settings button extender 3D printable
So the drawback with these gimbals and probably others is that the one side is not accessible.
On this gimbal, it’s the side with the settings/wifi button.
I made this so I can turn on the wifi and use the settings button without using some type of tool to access it.
Hope it helps someone.
Tarot3Dgimbalgoprowifibutton
Edit:
Just so you don’t go through how to attach it, I used Elmer’s Spray Adhesive. Sprayed onto a cotton swab and applied to this device, not the gopro itself. Just to the side parts and the top and bottom obviously.
