I use a Pixhawk with Arducopter 3.3 and I want to trigger the camera with mavros.
I try with rosservice call /mavros/cmd/trigger_control 1 0
but it answer :
success: False
result: 3
And nothing in mavros terminal:
The link is working as when I call : rosrun mavros mavsafety arm
In terminal: Request failed. Check mavros logs
And in mavros terminal: [ERROR] [1476375492.460409636]: FCU: PreArm: inconsistent compasses
Is /mavros/cmd/trigger_control supposed to work with ArduCopter or only with PX4 firmware ?
How to trigger camera via mavros ? With RC_Override ?
3 mean MAV_RESULT_UNSUPPORTED : Command UNKNOWN/UNSUPPORTED
EDIT : Or it is MAV_CMD_ACK_ERR_ACCESS_DENIED = 3
But 203 is what Mission Planner use for triggering: MainV2.comPort.doCommand(MAV_CMD.DO_DIGICAM_CONTROL, 0, 0, 0, 0, 1, 0, 0);
How to forge the same message with mavros ?
With mavproxy, “cammsg” return me the same error.
I just test in copter3.4 and both mavros and mavproxy commands that you used are working. Normally, it should be supported in copter 3.3. I don’t have pixhawk to test right now . I will give a try on monday on a pixhawk with copter 3.3
Thank you, so it is not an arducopter problem, nor mavros or mavproxy.
I think I’m just missing something, like setting SYSID_MYGCS.
I’ve tried 1 and 255 but same error.
Maybe I’ve missed something else ?
I have updated MAVProxy with: sudo pip install -U pymavlink MAVProxy
Using Mission Planner and click on “Trigger camera Now” work. => So it is not a config problem on Pixhawk side, right ?
Using mavproxy in SITL mode it works.
Their is a major difference between your config and sitl : you are on copter 3.3 and sitl is 3.4 . I will test monday on real pixhawk . But it is strange that is works with mission planner and not with other. I will test and get back to you ok ?
I tried on two others computers and the behaviour is the same.
Probably a software version mismatch… all 3 computers where using:
Ubuntu 14.04
ROS indigo
Mavros from ros-indigo package (maybe that’s the problem ?)
After doing a “sudo pip install -U pymavlink MAVProxy” I don’t see the error message in mavproxy but nothing seems to work (not able to change mode for example)
Still the same error in mavros.
I will try to build mavros from source and maybe also 3.4. Is it safe to fly with it ?
