I have a brand new Pixhawk2. Initially, when connected all seemed fine. Then, all of a sudden, it just didn’t connect via USB any longer to either Mission Planner or QGroundcontrol.
Trying everything:
Different USB cables.
Different computers
Different SD cards
Re-formated SD cards
Tried different (old) Pixhawk which was connecting fine
Installed octa-8 firmware instead of quad-4 firmware and back again.
None of this solved my problem.
Then, after installing a complete different fw, Rover, the Pixhawk was able to connect. Back to Quad-4 fw again and still working.
Summary: Don’t forget to install a complete different fw when you’re not able to connect to your Pixhawk.
Hopefully this will help any of you that might have the same issue.
Hi Tomas.
Had the same problem.
New PH2.1 will not connect to Mission Planner. PC with Win 8. Restarted Computer, instal and remove Mission Planner twice. Did try different usb ports, COM6, works with other applications.Using both Wizard and initial setup, but nothing works
Message, No Heartbeat! or No response from board.
Happy this worked for you, but in my case it did not
