Just curious, does anyone else have a lot of X axis vibration, relative to the other axes? Is that just because of the way the FC is mounted in the airframe?
That’s not that high and about where mine are with no consequences. I figured it was prop balance.
My drone flies fine too, I was just surprised to see a lot more X than Y vibration. I would have thought that an unbalanced prop would cause roughly the same translation in both X and Y.
There is more vibration in pitch on this frame due to an asymmetry and resonance in the frame. The resonance is around 80Hz, which is why we have a notch filter set at that frequency.
Interesting, and thanks for the info.
