SITL Quadplane Simulation
For ArduPlane Version 3.7 I used the command: “sim_vehicle.py -L KSFO -f quadplane --console --map” to build and launch the simulator as directed here…
http://ardupilot.org/plane/docs/quadplane-simulation.html
This no longer works.
It keeps telling me quadplane is not an option.
Does anyone know the new command or what the problem may be?
Thanks,
Shane
That command worked fine for me (using Cygwin under Windows).
Is there a particular reason you’re using Arduplane 3.7 rather than the latest source code? Does the command work with the latest source code? Does it work with different frames (like plane or hexa)?
What I was trying to say was it worked for 3.7 but not for the new 3.8 beta code.
-Shane
very strange, I just tried it here and it worked fine. Are you sure you’re getting the right sim_vehicle.py?
Try this: type sim_vehicle.py
perhaps a $PATH issue?
Turns out this was the problem…
Just pulled the master.
Looks like it’s still having the same problem.
Auto
FBWA> APM: Executing nav command ID #84
APM: Resetting previous waypoint
Got MAVLink msg: COMMAND_ACK {command : 11, result : 0}
APM: Reset alt target to -2.6
waypoint 1
AUTO> Mode AUTO
arm throttle
AUTO> APM: Throttle armed
Got MAVLink msg: COMMAND_ACK {command : 400, result : 0}
/vagrant/Tools/autotest/run_in_terminal_window.sh: line 54:  3580 Aborted                 (core dumped) $cmd $* &> "$filename" < /dev/null
no link
link 1 down
no link
no link
no link
no link
Hello Shane,
I’m having the same issue, did you manage to solve the problem?
