SITL, first project, fast plane
I would like to try my first steps in SITL. I managed to compile and fly the test plane some rounds.
Now I would like to use a different airplane and simulate a fast jet, just to see how ardupilot handles it.
I created a new model and engine with the jbsim form [0] and stored it in …/Tools/autotest/aircraft/jet.xml
then I started SITL with sim_vehicle.py --console --map --aircraft test
There are no warnings in command line but how can I say the correct airframe is used?
Best regards
Sebastian
[0] http://jsbsim.sourceforge.net/aeromatic2.html
Your command lacks the switch to use your new aircraft model in JSBSim.
Hi, as posted by Tridge and copied here for convenience:
" I’ve added support for different JSBSim models to master, and updated the docs here:
http://dev.ardupilot.com/wiki/setting-up-sitl-on-linux/#using_a_different_jsbsim_model
You just use the -f option, like this:
sim_vehicle.sh -f jsbsim:MyModel"
(source: https://github.com/ArduPilot/ardupilot/issues/3083)
