I am using an APM 3.1 connected to my ezuhf receiver via cppm. I can’t find rssi_channel in the list of parameters that I can download from my APM. I’m on arduplane 3.4.2, so I believe I should have it, but all I can see are the rssi_pin and the rssi voltage parameters.
I have my ezuhf set to output RSSI on channel 7 (channel 8 is being used for flight modes). I was hoping the solution would be as simple as connecting the channel 7 servo output to the A0 or A1 pin, and then setting RSSI_pin to A0 or A1, but of course that would have been too easy - it doesn’t seem to work either.
I used the Tower app to download the parameters via 915MHz telemetry radio. Might I not be getting the full parameter list?
