PRX and Obstacle Avoidance
Hi all,
Im trying to implement obstacle avoidance on a quadcopter I am building (using Pixhawk and Arducopter). Im trying to do obstacle avoidance with 8 horizontal Maxbotix LV EZ0 sensors covering 360 degrees. The distances are sent to the Pixhawk via an arduino using mavlink, and Im guessing that I have to set PRX_TYPE to Mavlink for that to work. However, as shown in the picture below, there only seem to be 2 options. How can I get this to work? (Thanks in advance)
So, I managed to change it to Mavlink using APM Planner, but dont seem to get that option in Mission Planner. @Michael_Oborne maybe this is something that could be changed?
Additionally, would be very grateful if someone could explain what CAn and CDist stand for under the PRX dataflash logs?
Hi Devansh,
For Mission Planner, have you tried regenerating parameters? You can always set it in the full parameter list.
Angle and distance of the closest object.
Thanks, that makes a lot of sense.
But for some reason, I am just not being able to “activate” obstacle avoidance on the quadcopter. I am under the impression that if I take off in stabilize mode, then there will not in any obstacle avoidance, but as soon as I switch to Alt-Hold mode, it should be activated. However, the quadcopter doesn’t seem to really move away from obstacles when brought close to them, and CDist in the logs seems to be ~0.20m even though Im guessing that it shouldnt go under 2m.
Any thoughts on why obstacle avoidance may not be starting for me?? Ive attached the log file of one of my flights if it helps :slight_smile:17-04-21_21-58-48.bin (330.2 KB)
I haven’t played with this feature, so I don’t know much about details, but I think that if you are already inside the 2m it won’t move away.
@rmackay9 Can you confirm this?
Thanks, that does make a lot of sense. Let me try testing in a larger area and see if it works when I move in from outside 2m…
