Programming library examples on the Pixhawk with Eclipse
I am a beginner according programming and I was going through the Ardupilot Programming libraries: http://ardupilot.org/dev/docs/apmcopter-programming-libraries.html . On the Arduino IDE it was easy for me to load the examples from those libraries. Now I am new to the eclipse environment and I do not know how to make the build and the upload for PixHawk. Sure the big code px4 code is functioning well with the make command but I want now those small library examples running on Eclipse.
Please help me because I am a beginner in eclipse and I need to know step by step how to use the library examples of Arducopter.
In the internet I found only one following video without a description on how the library example was programmed:
Can you explain to me how I can program that?
Thank you in advance
