Problem uploading firmware 3.2.1
I am using apm2.6 and and try to upload custom firmware for quadcopter ac3.2.1 .
I connect apm via usb to pc but not click on connect button,load custum firmware then it say do you use linux board i click on no (since i use window) then it detect and upload firmware and verify board and lastly display done on missiom planner.
But the problem is when i click on connect button on mussion planner it say connect apm get parameter from apm and then display you cannot upload firmware bia mavlink please disconect… and so on.
But firm ware upload done is displayed then i had click on connect so why it is display this. Please show me solution
Say “Yes” to linux board.
It is asking about the APM2.6…not your OS
After loading, completely power down the APM and then try to connect.
If it still won’t connect, I would suspect the cable.
Yes, you just loaded the firmware with it but it might be just good enough of a cable for that but not good enough to connect.
This is standard if you are still on the “Load Firmware” page.
Go to another page such as “Flight Data” and connect.
Thanks sir for your reply, actually i am new candidate for ardupilot. Any way thankx it solve my problem
