after running command : sim_vehicle.py --console --map --aircraft test
Failed to load module: No module named adsb. Use ‘set moddebug 3’ in the MAVProxy console to enable traceback
Loaded module console
Failed to load module: No module named map. Use ‘set moddebug 3’ in the MAVProxy console to enable traceback
I just had the same problem.
I had a “fresh” Ubuntu install (16.04) with python 3 only.
Then I followed the steps to run SITL and also checked all the dependencies as khacyr listed.
Still did not work.
So, to find out what was wrong, I issued this command in the mavproxy console window (yes, thank you perterbarker!):
set moddebug 3
and
module load map
this gave me an error with some clues: libjasper.so.1 was missing!
Could not install it “easily” on Ubuntu… apt-get install libjasper-dev did not work
So I installed it directly from a debian package (from here: https://packages.debian.org/jessie/libjasper1 and one of its dependencies that were missing also from here: https://packages.debian.org/jessie/amd64/libjpeg62-turbo)
To install directly, I did
Yeah, I forgot to mention I had installed python 2.7 so in my case, it did not fail because of that. It failed because I did not have the 2 libraries (libjasper1 and libjpeg62-turbo)…
Try downloading MAVProxy for python 2 rather than python 3, by typing python -m pip install MAVProxy. The script uses python 2 by default and pip takes 3 in case you have both 2 and 3 on your system
I did the same but getting the below as the error. Can you please help with this?
ModuleCmd_Load.c(208):ERROR:105: Unable to locate a modulefile for ‘map’
