hi guys
i try to make ardupilot in windows from this link
but i got this err
any idea about my problem ?
i use pixhawk and ArduCopter
thanks
hi guys
but i got this err
Do you have the latest Windows toolchain installed? Have you tried to do a make clean and then compiling again?
I think if you scroll up you will find that MAVLink header generation has failed.
As @OXINARF hints at - I believe this problem has been fixed in the most recent Windows toolchain.
Failing that, you can install the latest Python packages yourself; https://github.com/ArduPilot/pymavlink/wiki
Peter
My 2 cents… To don’t mess with any toolchain installation on Windows platform you can build it using Vagrant and VirtualBox.
Unsure about current directory at step 4. You can check it with pwd command.
regards,
Dmitry
