Yes and also you have to set the data rate on this telemetry 2 port : the rate messages are sent from the vehicle can be controlled using the SRx_* parameters (i.e. SR2_POSITION).
I have a few FPV setups that exhibit the same non-startup action with the OSD.
These include standard Minim and Micro Minim with different firmware.
What I have found is seems related to the camera in that if I disconnect the video line from the camera to the OSD, only the video not the End, and reconnect, the OSD starts and operates normally.
This happens with the Sony CCD’s mostly.
I simply put a push button disconnect in the video line so that after boot, when having to push the PH safety switch. I also push the video switch to momentarily disconnect the camera and the OSD starts up.
So the OSD doesn’t reboot, it is already running, it just doesn’t seem to fire up the video encoder chip.
Hi Mike, tried t disconnect and reconnect the yellow video wire from cam to OSD, but I can still see same displayed message No data!
I’ve installed MWOSD firmware now and applied these settings:
SERIAL2_BAUD, 57 (telemetry output at 57600)
SR2_EXT_STAT, 2 ( 2hz for waypoints, GPS raw, fence data, current waypoint, etc)
SR2_EXTRA1, 5 ( 5hz for attitude and simulation state)
SR2_EXTRA2, 2 ( 2hz for VFR_Hud data )
SR2_EXTRA3, 3 ( 3hz for AHRS, Hardware Status, Wind )
SR2_POSITION, 2 ( 2hz for location data )
SR2_RAW_SENS, 2 ( 2hz for raw imu sensor data )
SR2_RC_CHAN, 5 ( 5hz for radio input or radio output data )
but still no data.
Have you tried with TX and RX swapped?
thanks, yes I did, but still no data available
I’ve replaced my Minimosd micro with a new one, new wiring still the same problem… I’m wondering if Pixracer supports OSD via telem2…
I have Pixracer and I tried it on telem2 and it works just fine.
Mike
What I’ve seen this morning is RSSI is working. Does it mean there is a communication working between Telem2 and my osd? Do you firmware with MWOSD Chrome app? What option did you choose, MAVLINK or PX4 when you have to select the firmware? Is there something with MWOSD that I should change? Could you please tell me if you have the same SR2 parameters (see above) like me? If not could you share your parameters? One more info, I power my minimosd micro from the 2 pins (Ground +5V top of the pict), not from the controller, just the ground and rx and tx are connected. Am I wrong? Thanks for your precious time!
I have a mini MimimOSD module that I got from hobby king a while back. I made a cable for it so all I have to do is plug it in.
I am running the original software that came with the board which is OSD 2.2 that is very old.
Here is a picture of them. The bottom one is the one I use.
These board must be running a version that supports Mavlink to work.
Mike
Wire connections:
JST GH connector: https://wiki.dronecode.org/workgroup/connectors/start
Pin1 power to Pin3 Power minimOSD
Pin2 Tx to Pin4 Rx minimOSD
Pin3 Rx to Pin5 Tx minimOSD
Pin4 CTS to Pin6 GRN minimOSD
Pin5 N/C
Pin6 Gnd to Pin2 minimOSD
Mike
I have this except pin1 not connected to FC because I power minimosd micro with external 5V power. But I let the ground connected to the FC. Is this wrong?
As long as there is a common ground you are good.
Mike
is it a way to check there is an output from my telem2? connecting direct tx rx to usb FTDI interface and to read values with arduino console?? I really understand because everything else is working. Frsky telemetry to taranis is ok, should just be a stupid lost parameter…
You could try one of these units. Sik Telemetry Radios
They come with the correct cables and you can use Mission Planner to see the data.
Mavlink data is binary data and is going to look like garbage on the screen.
Mike
I’ve tried with a WiFi telemetry on the Pixracer, didn’t worked. I did try on a Pixhawk. I reset it before to default parameters, all SR2 values were set to zero. I switched off the Pixhawk, connected the WiFi telemetry module, reboot and was able to connect via WiFi. Then I looked at the SR2 parameters (connected it to telem2) and they were automatically feeded! So I tried to put all SR2 parameters to zero on Pixracer, but it didn’t worked…
Here’s my 2 cents… there is a misleading definition in the ports assignation on PixRacer, please confirm that you are connecting to the ‘‘good’’ ports
yes, I confirm, connected on serial 2 telemetry 2
Do you have a FTDI USB-Serial converter - or an Arduino handy ?
It could be helpfull to read both Serial 1 & 2 to check if data is outputting
@ 57600 you will see some messages through the garbage
