Pixhawk not giving output
hi guys, i connected my pixhawk to my TBLE-02S brushless motor and FrSKY TFR6 7CH receiver. but how come its not working when im controlling it with my receiver. i have used mission planner to check if there’s input to the pixhawk. it does have input but the pixhawk is not giving output to the esc. please help. thanks :slight_smile:
So I take it that your radio is working correctly and is feeding data into Pixhawk - i.e. you do see changing values in the Radio Calibration view in Mission Planner when you change your stick positions, right?
Are you able to arm successfully?
And if so, did you calibrate your ESCs?
