mogli73
(Manauel)
September 22, 2016, 4:53am
1
Hi to all
I’m looking for older firmware Hex-files to download.
I have found this:
http://firmware.ardupilot.org/Plane/
and this:
http://discuss.ardupilot.org/t/ardupilot-older-firmware-where-can-i-get-faq/7456
But here only the acual version and beta version is aviable.
I know it is possible to install older firmwares directly in missionplanner. But I want to store the files localy.
Thanks for your replays
Cheers
R_Q_Robert
(R Q Robert)
September 22, 2016, 5:50am
2
To obtain hex files .
Go to Mission Planner >> Initial Setup >> Install Firmware >> Pick Previous Firmware.
Select a firmware as shown in below pic.
Click on a frame type and install the firmware.
After doing this , a hex file is downloaded in your Mission Planner’s directory named as firmware.hex.
So use this and save it for later use.
mogli73
(Manauel)
September 22, 2016, 2:15pm
3
Thank you for you answer!
I will try it. But your solution sounds good!
R_Q_Robert
(R Q Robert)
September 22, 2016, 2:23pm
4
Helping each other is the strength of our community.
mogli73
(Manauel)
September 22, 2016, 6:34pm
5
I tried it. It works only if the APM is connected. Otherwise I get en errormessage:
mogli73
(Manauel)
September 22, 2016, 6:36pm
6
Anyway for me it is fine. If my APM is connected via USB then I can upload the files an I find the hexfiles. It takes some time, but this is ok.
Thanks again!!
Cheers
mogli73
(Manauel)
September 22, 2016, 6:48pm
7
I’ve just tried to
download a few firmwares to my APM.
But unfortunately it doesn’t work at all. After
downloading I deleted the hex-file to be sure it is not always the same. I
still can install firmwares to my APM. But there is no new hex-file in the MP
folder.
mogli73
(Manauel)
September 22, 2016, 6:57pm
8
finaly I found the downloaded hex-files on …user\documents\Mission Planner
