Is it better to use LiDAR (eg LightWare SF10) (expensiv but precise) or Ultrasonic (cheap and less precise) sensors for obstacle avoidance?
And is there a way of using two sensors looking left and right and deciding if the rover has to go to its left (obstacle at the right) or to the right (obstacle at the left).
Hi Yvo, You could consider scanning a sensor - either laser or ultrasonic - using a simple servo. This gives you more than one point on each side of center so that you can confirm your avoidance decision and you could even go as far as creating forward looking maps so that you can make longer term navigation decisions.
For a complete, compact solution the LW20 has a built-in servo driver and left/right alarms to simplify your software. There is a full API available.
Currently we only have basic avoidance on Rover that use max 4 sonars (I don’t know if laser rangefinder are supported) see http://ardupilot.org/rover/docs/sonar-sensors.html
The full support for avoidance, multiple input , slam etc. is planned for this summer!
