Love the display!
do we need a breakout board for PixRacer to connect the display, or can I just parallel the connections from the PixRacer to the +,- and i2c lines to connect? Works OK on Bench but not sure about those breakout boards being anything other than a group of sockets connected in parallel to the i2c bus.
Joe
Hi
I have tried the DIY Oled on pixhawk 2.1 and IT doesn’t work but it works fine on pixhawk.
Hi, probably you need to connect it to another I2C bus on PH2.1. There isn’t implemented yet a bus number parameter for display.
I have also tried it on GPS 2(I2C).No luck.
Hi. Needs to change row function. I try todo it
10 дек. 2016 г. 6:56 PM пользователь “mike kelly” <
noreply@discuss.ardupilot.org> написал:
I can confirm this works with the Waveshare 1.3" OLED module with configurable interfaces:
https://www.waveshare.com/1.3inch-oled-b.htm
It supports 3- and 4-pin SPI, and I2C, and is apparently ok with 5V supply. To configure the module for I2C you have to move a soldered jumper on the back, tie CS and D/C low, and tie RES high. It is an SH1106 module, so set NTF_DISPLAY_TYPE to 2.
Nice work, It´s possible to change data to display? Eg. add rpm info for a nitro plane? Thank´s
