Hi! I am building a VTOL QuadPlane on an RQ-7 Shadow Balsa/Ply kit; with a Pixhawk.
I have used ArduCopter on the APM2.5(and its variants) for about four years now. I have also used APM Plane on the Pixhawk for a few months. I am pretty comfortable using Mission Planner as my GCS as that’s the only one I have ever used.
From what I have understood, correct me if I am wrong, I can use the PX4 Flightstack with QGC and the APM Flightstack with Mission Planner. On the PX4 documentation for Quadplanes they mention to use QGC.
I would like to use Mission Planner as I am more familiar with it. Does QGC have any QuadPlane specific advantages? Also, I have never setup an airspeed sensor on a fixed wing before, is there any benefits with either GCS regarding this? I don’t want to mess up this part of my setup since I understand that the airspeed sensor is critical to the performance of a quadplane.
Hi! I generally like to use QGroundControl better because it had a much cleaner format and it’s easier to see what’s where.
QGC is the only one available for mobile users.
Also, if you are using PX4, you have no choice but to go with QGC.
If you are using ArduPilot, you have a choice between QGC and MP. I use MP because I’ve heard that QGC is very buggy with ArduPilot.
Finally, if you are using APM, it’s best to stick with APM Planer.
Thanks for the explaining. It seems my equipment is “Old” school.
Tooo…many question about the coming new FC system
Just wonder the Matek, is that about the same as APM(I can upload the firmware and work with mission Planner and Qgroundcontrol)?
Also, how about the Pixhawk 4, which one is better(or what’s the difference)
I do also have some sensors(sonar, Optic Flow ), and 3DR telemetry, wifi… when I purchased APM long time ago, can I still use it on Matek system(Or is that I need to purchase all again?)
What I like to play is UAV(drone… and maybe would go for plane later), and play with the way point…
Is the one you suggest is the best choice in low budget. ThX again!
I use Ardupilot to fly traditional helicopters 4.0.5 version.
Used QGC but found out that the parameter list lacks parameters and have non used parameters as well… is it something i installed wrong ?
installed the latest QGC application for windows, with the same results.
The parameter list comes from the vehicle. So if there are missing parameters then it’s the firmware that isn’t sending them. QGC shows all the parameters from the vehicle. I think MP has various views where it filters out some parameters and it also has a full parameter view. You may be confusing a filtered MP view to QGC full list.
I am trying to use QGC on my macbook to work with PixHawk 6c.
Downloaded the latest stable firmware on Pixhawk 6c.
Selected the airframe to be Quadcopter (3DR DIY Quadcopter)
Then calibrated the sensors (all of them).
Now came to Radio…
I am able to bind the radio (Spektrum DX9) with the receiver SPM4650c
But the QGC is not displaying any binded radio and hence I can not calibrate the radio on QGC.
What could be wrong!?
