Michael,
On the LOITER_TURNS command, would it be possible to display the exact circle trajectory around the placed waypoint using the entered radius value? And, if the initial circle is not the correct size, could there be some kind of grab tag on the circle that could be “click & hold” with the pointer and dragged to the required size that would automatically adjust the radius value at the same time?
Thanks for your time!
