Is is possible to change the flight direction on a survey?
Some apps allow us to change flight direction according to current wind direction, when we plan a survey Tower automatically chooses the direction of the flight pattern. Can we change it a perpendicular flight plan or something similar?
Thanks
Best regards
there is an option to option to rotate the flight pattern according to your needs. The bar above the flying height.
In the last version it is possible to fix the copters´ orientation during the mission as well.
Hope that helps a bit…
Ulrich
