How to setup a amperes limit for the remote control
Dear support
I am using a Xbox control to use with a boat. Everything is working, but is possible to limit a maximum amperes when you are using a remote control? If yes, how could I set this limit?
Regards
Anderson
You can’t limit based on amps but you can limit throttle which in turn will limit your amps. Look at THR_MAX parameter.
Thanks, Grant.
