eric,
i have the same problem, how can i downgrade to 3.4.6?
Hi
In Mission Planer under “Install firmware” and in right lower corner there is a option where you can select previous firmware versions. Remember to calibrate after load…
it works, many thanks.
but that you mentioned it was hardware bug? how can i fix it ? could you help on this?
I got a new Pixhawk.
Oops…
was it single unit failure? or hardware bug?
i cannot buy a new one…
my pixhawk version is v2.4.3
I am interested to know how an hardware fault can go away with different software versions.
personally if it was me experiencing this issue. I would completely wipe the board clean and start from scratch with loading the software.
cannot get root cause, anyway after change to 3.4.6 or lower version, the gps working.
I downgraded to 3.4.6 myself because my neopixel external leds does not work with
3.5. Curious indeed
so that means the rc3.5 with some bugs?
