Flightmode Selection Problem Turnigy 9X
Hi, I’m trying to fix my copter but I get a problem when I try to set the PWM range for the different Flightmodes. I have a Turnigy 9x and when I try to fix the highest PWM, I can not go above 1500, so my range is very small and I can only have 4 Flightmodes. Could someone help me?
Thanks!
Can you not change the PWM range on the radio itself? I know I had to do some fiddling around with that on the Taranis.
If I can, I do not how. Could you please help me? How could I do it?
On a turnigy I wouldn’t have the slightest idea how to do it. Might be in a screen called mixes or outputs.
I did with an option that is called MIX, and I can change the PWM range between 900 and 1500 but I can’t go above it. The problem is, if I only can take my radio between this values, I can only have 4 Flightmodes. DO you know how to fix it?
Try changing the " end points " in transmitter .
