Hii…
I’m building a S500 quad…
I’m using APM 2.8 as my Flight Controller…
I’m using SunnySky X3108S 720kv Motors…
Do the EMAX 30A BLHeli OPTO ESCs work with APM 2.8 ??
Are there any issues with these ESCs not working with APM ??
Or Could you suggest me any good 30A ESC with “BLHeli” or “BLHeli_S” that can drive 720kv motor without any problems ( such as sync issues ) ???
Thank you in advance…
They work fine but you might have to change the motor timing settings on blheli escs to work with low kv motors.
Hello Sir,
Thank you for your reply…
How are the “Hobbywing X-Rotor ESCs” ?? Are these ESCs good ?? DO they work well with APM and SunnySky 720kv Motors ??
I’ve heard some good things about these ESCs…
And whats the Differencend between the Hobbywing “X-Rotor ESC” & “X-Rotor Pro ESC” ??
Thank you☺
