Custom or modified mavlink message not working in ArduCopter
Hello.
I want to add custom mavlink message to ArduCopter firmware with my ErleBrain2.
I’ve added this code to ardupilotmega.xml in modules/mavlink/message_definitions/
<message id="239" name="MYDEBUG"> <description>Send a debug value. The index is used to discriminate between values. These values show up in the plot of QGroundControl as DEBUG N.</description> <field type="uint32_t" name="time_boot_ms">Timestamp (milliseconds since system boot)</field> <field type="uint8_t" name="ind">index of debug variable</field> <field type="float" name="value">DEBUG value</field> </message>
and added usage code near raw_sensors stream to test original debug and “mydebug” ones.
mavlink_msg_mydebug_send(chan,AP_HAL::micros(), 1, 100); mavlink_msg_debug_send(chan,AP_HAL::micros(), 1, 100);
then compile code and upload it to ErleBrain2.
I have python code to test this:
master = mavutil.mavlink_connection('10.0.0.2:6000')
while True:
    print 'Waiting for DEBUG'
    print master.recv_match(type='DEBUG', blocking=True)
    print 'Waiting for MYDEBUG'
    print master.recv_match(type='MYDEBUG', blocking=True)
Also i have C code to emulate copter (modified example from github.com/mavlink/mavlink/blob … link_udp.c):
         mavlink_msg_debug_test_pack(1, 200, &msg, microsSinceEpoch(), 100, 200);
         len = mavlink_msg_to_send_buffer(buf, &msg);
         bytes_sent = sendto(sock, buf, len, 0, (struct sockaddr*)&gcAddr, sizeof(struct sockaddr_in));
         mavlink_msg_debug_pack(1, 200, &msg, microsSinceEpoch(), 100, 200);
With mavlink_udp.c - all works fine. But with ArduCopter.elf on my erlebrain2 i have problems.
For original debug - all works fine. But with custom message - not.
Seems that it does not sends from firmware at all.
Also, if i try to change id or name of original debug - it’s not working.
Can someone give me hint to solve this?
After some debugging, i found that message is sended to
Packets generated by mavlink code:
[code]mavlink_msg_debug_test_send(chan, AP_HAL::micros(), 100, 200);
0xfe 0x9 0xf1 0x1 0x1 0xef 0x51 0xde 0x53 0x2 00 00 0x48 0x43 0x64 0xe9 0x11
0xfe 0x9 0xf2 0x1 0x1 0xef 0x67 0xde 0x53 0x2 00 00 0x48 0x43 0x64 0xe2 0x4
mavlink_msg_debug_send(chan, AP_HAL::micros(), 100, 200);
0xfe 0x9 0xf3 0x1 0x1 0xfe 0x75 0xde 0x53 0x2 00 00 0x48 0x43 0x64 0x3d 0xc
0xfe 0x9 0xf4 0x1 0x1 0xfe 0x83 0xde 0x53 0x2 00 00 0x48 0x43 0x64 0x2 0x19
[/code]
with tcpdump i can see only original messages, but not custom ones.
Any ideas about reasons?
