Hi all,
We’ve pushed some changes recently from https://github.com/ArduPilot/ardupilot/pull/4590 that, among other things, create a new Waf tool called ap_persistent. That reduces clean build time by persisting scanner results across clean commands. It does so by adding some new attributes of BuildContext to Build.SAVED_ATTRS
If you have already built Ardupilot before those changes and try to build again after updating your local repository, you’ll probably run into something like:
Traceback (most recent call last):
File "/path/to/ardupilot/modules/waf/waflib/Scripting.py", line 165, in waf_entry_point
run_commands()
File "/path/to/ardupilot/modules/waf/waflib/Scripting.py", line 266, in run_commands
ctx = run_command(cmd_name)
File "/path/to/ardupilot/modules/waf/waflib/Scripting.py", line 250, in run_command
ctx.execute()
File "/path/to/ardupilot/modules/waf/waflib/Scripting.py", line 616, in execute
return execute_method(self)
File "/path/to/ardupilot/modules/waf/waflib/Build.py", line 252, in execute
self.restore()
File "/path/to/ardupilot/modules/waf/waflib/Build.py", line 319, in restore
setattr(self, x, data[x])
KeyError: 'ap_persistent_task_sigs'
That’s expected and actually a bug in Waf. waf distclean
should get rid of that error. I’d just like to remind you that that command will completely clean the build for all boards.
Best regards,
Gustavo Sousa
