Great news, Randy!
We’ll try to fly test the release by the end of the this week on Navios and Edge.
Would be also great to see these bug fixes as well in the next RC.
Great news, Randy!
Great to see the bug in the Septentrio driver has been finally nailed.
Will try to do some testing ASAP, but is might not be until after the weekend.
@sergbokh,
Re the fix to relative-position-NE-to-home, this only affects the LOCATION_POSITION_NED mavlink message sent from the vehicle to the ground station. This is not a commonly used message so I don’t think you’ll notice the change. Most ground stations use a different message which provides the latitude and longitude of the vehicle and allows it to be displayed on the map.
By the way, any feedback (positive or negative) re the current beta release (3.5.3-rc1)?
I think it’s fine but a comment or two on a successful (or unsuccessful) flight would give me a touch more confidence…
Randy,
I flew this build today. I noticed a few GPS gliches, but I cant say if it was related to the build. I was flying near a cell tower which may have caused the gliches. I have the AsteRX as my primary GNSS, which is backed up by a standard U Blox.
I’ve been chasing a bad logging error for months. I normally fly RTK fixed. Several flights last week I didn’t need RTK and never got a bad logging cue in the HUD. So I began to wonder if the AstreRX with a correction was causing the bad logging. Today with 3.5.3-rc1 and RTK fixed I never got any bad logging indications. I am hopeful this new build fixed my persistent logging errors.
Great work,
Thank you,
Dave
Flew four times today. Unfortunately, got bad logging indications on 3 of the 4 flights and we weren’t sending a correction to the drone. Don’t know if the bad logging and AsteRX are related or not, but 3.5.3RC1 didn’t solve the logging issue.
We recently started using PPK instead of RTK, Don’t have a ton of data but I’ve probably taken 1,500 pictures with Copter 3.5 and PPK and they all worked fine.
Today I had significant drop outs in my PPK data. Took over 400 pictures and roughly 1/4 had no data. I have no idea if this could be related to the septentrio modifications, but want to through this observation out to the community for consideration.
Flying again tomorrow. I’ll report back when able.
Thanks,
Dave
OK, thanks for the reports.
I’m not the expert in either the GPS or logging areas but I can’t immediately think of a way they could be related. I’ll point this report out to Peter Barker and Michael DuBreuil who are the experts and maybe they will have some ideas.
For me, my best suggestion is probably just to ensure the SD card is high quality with a fast write speed.
I’ve just pushed Copter-3.5.3 just now so it should appear in the ground stations in a few hours.
@skyveyor when you say dropouts in your PPK data you are referring to the AsteRx-M’s SD card correct? And you are assessing the pictures don’t have data as the result of GeoTagZ or something else?
Exactly. Most of my flight was GPS status 1, which I’ve never seen before. This led to a NO PVT output from GEOTAGz.
I think my problem may have been a loose antenna but more troubleshooting and analysis is required.
Thanks,
Dave
Flew 4 times today and each flight I had a bad logging cue. I’ve swapped SD cards, reformatted SD cards and even swapped out flight controllers. The stubborn bugger persists. It’s got to be something with my set up. I have a class 10 card in there now. The only thing I haven’t tried is formatting a high speed SD card as FAT instead of FAT32. FAT is only good up to 2Gb. I haven’t gotten around to ordering a high speed 2Gb card. Got plenty of 32 and 64 hanging around though.
Dave
@skyveyor can you share some logs? Are you stopping the SD card log before removing power? It is a known problem that if you don’t cleanly stop writing the SD card log file before removing power that it can be corrupted and you can lose data from the AsteRx-M’s log. (There is a button on the board to start/stop logging you should be taking advantage of).
Although a GPS status of 1 is NO_FIX which lends a lot of credibility to an antenna problem or interference. In RxControl what is the GPS’s RF power from the status panel? (The radio looking symbol at the top). The other thought of course would be interference, which you could use the spectrum analyzer for.
WickedShell.
My last email was poorly written. I had two separate issue that I merged into one confusing thread. The problem with the AsteRX was two-fold: A) the antenna was loose and B) poor procedures. I was not habitually turning off logging before powering down. I missed that user note but was reminded by Dave at Septentrio.
The other problem I have yet to solve in bad logging on the pixhawk. Because I can’t geotag images with no logs, I ended up buying GEOTAGz for PPK EXIF data. Nice interface but not as simple as mission planner geotagging with DFlogs.
Thanks for your input,
Dave
@skyveyor okay that makes more sense as to what was happening. If you are flying copter 3.5.3 you can set GPS_RAW_DATA 1 which will add as part of the GPS arming checks a check that the AsteRx-M is currently logging to it’s SD card.
I’m slowly looking for a way to automatically stop logging when the vehicle is disarmed for example, but due to the configuration time on getting logging started again I can’t do it the moment a user asks for the aircraft to arm. So I’m not sure of any good way to automatically start the logging yet. But I would like to get this feature sorted out as manually stopping logging is a large pain.
That is a great tip and addition to 3.5.3. It’s nearly impossible to see if the red LED is flashing in bright sunlight. I often have to cover the drone with my hat to see if the LED is flashing. Even then it’s hard to see.
For me the logging button is easily accessible so turning the logging on and off is a minor inconvenience.
Have you talked to anyone from Septentrio about a possible fix on their end?
Dave
@skyveyor The only fine print note is that if your SBF isn’t being auto configured correctly it won’t detect it. Fixing SBF configuration is 95% done here: AP_GPS: SBF Enhancements by WickedShell · Pull Request #6986 · ArduPilot/ardupilot · GitHub as well as detecting more failed configurations correctly.
While the button is in general easy to press, I’ve witnessed that users have a high tendency to forget to press this, so I’m looking for a way to minimize the users chances of screwing this up because they forgot.
About the logging or minimizing the corruption? The enable/disable logging at run time is the main way to fix it that I’ve discussed with them in the past. FAT32 filesystems are much more prone to corruption, however I can’t really track why it seems to be more of a problem on the GPS log then autopilot log.
WickedShell,
Thanks. Is this pull incorporated in copter 3.5.3 or is it still under review?
Dave
Any chance any of the overhead issues discussed in the GIT thread could cause bad logging on the pixhawk? It’s not the SD card, Pixhawk or parameters. It’s got to be something related to my hardward for the firmware running the hardware. My problems started when I integrated the AsteRX, but I have nothing conclusively pointing to it as the source of the problem.
