Catamaran boat
Hello, just start a new project, and i am a french newbie
Just want to make sure before i start buying stuff
Project is a catamaran with two engine
i think i will use the skid steering mode
One engine will draw 4amp
Automunius mode with google map and Rc radio controlled
That its
I will get the the:
arduipilot apm 2.6 or the new 3DR Pixhawk
3dr gps
3dr radio set 433 mhz
APM power module
I already have an arduino Duelinaove ,is this will be enought ? because of on PWM and two engine
Any sugestion on the radio controller Europe
With the skid steering what kind of motor drive or dual motor drive a can use 4amp DC motor
Thank you, any other info is welcome to help
philippe
No answer :frowning:
@phmadeira,
You might look at the Dimension Engineering Sabertooth dual motor controllers. The have a skid steering function built-in or you can use them as two separate motor controllers with the APM performing the skid steering function.
Regards,
TCIII ArudRover2 Developer
thank you for your answer
look exactaly what i was looking for
one step ahead
thank
did you design your vehicle?
yes
have a look
https://www.facebook.com/Filippe.zadeira/videos/10153108809331448/
