I am using a PixRacer on my S500 quadcopter running ArduCopter 3.4.6. The 5th pin of the PixRacer is connected via a signal line (signal & GND) to a Firefly Q6 camera. What I am trying to do is use channel 9 - which is assigned to a three-way switch on my FlySky TX - to control the camera via a PWM signal as stated in the wiki. The FlySky is configured to operate on SBUS, so I have 10 channels fully working and recognized on Mission Planner.
I can trigger the camera (switch between taking a picture and starting/stoping video recording) via Mission Planner’s servo tab using the first servo (numbered 5) but I cannot do the same using the three-way switch on my TX (which is on channel 9).
I have set the following on my ArduCopter set-up:
BRD_PWM_COUNT=6
RC9_FUNCTION=1 (to pass the RC signal to AUX1 which - if I understand correctly - is pin 5 on PixRacer).
Any help or tip in making this work is greatly appreciated.
@OXINARF: Francisco, I had a feeling that RC9 was incorrect but as the wiki does not have any information about PixRacer, I did not want to mess this up. So, basically, the PixRacer (as it does not have AUX ports) starts with RC1 (1st pin) and goes up to RC6. After setting RC5_FUNCTION=59 everything works just fine.
@iseries: After setting BRD_PWM_COUNT=4 I could not trigger the camera from Mission Planner anymore. You make a valid point for AC 3.5 but I have not tried it yet.
@dkemxr: I assume you are talking about AC 3.5, right?
@iseries It’s a little hard to explain without going into details, but all ports in Pixracer are Aux ports, they would correspond to same six Aux ports in a Pixhawk. And you want to set BRD_PWM_COUNT to the number of PWM outputs you want. If you set it to 4, then the two last pins won’t do PWM output.
@Frontier Yes, it starts with RC1. And yes, @dkemxr is talking about 3.5, where we (finally!) separated the input from the output.
Now I remember, I asked Randy this when it first came out because I have a relay set to turn lights on and off on pin 6. Wanted to know if it would support relay pins since it only had 6 pins and not Aux out pins.
