Hi all,
I have a problem to use camera shutter in MP.
I’m using Seagull MAP2 to convert servo signal to sony RX100 signal to triggering camera.
After i set the shutter channel (i’m using RC7) and set the others paramater to triggering camera where 1700.
After that the signal from shutter (rc7) always 1700 and triggering the camera without stopping.
Hi Kikislater…
before using RC7 i’m using aux2(rc10) and it also giving the same result…
the pixhawk output always send 1700 signal to map2.
from what i has observe, if the pixhawk has no gps signal, the signal from pixhawk is neutral (1500), then i try to arm my plane outdoor with GPS signal, then the output from pixhawk always 1700 send to seagul map 2.
