aidil
(suriyadil)
May 30, 2017, 1:00am
1
Hi all,
can somebody help me to select which camera parameter that i can use for my Sony RX100 M3 setting in MP??
I have try to set using the RX100 data but the mapping grid is to near to each others and the time taken is too long…
now im using arduplane and when the plane flying thru the waypoint, it will take a large turn and overshoot from the waypoint…
anybody can help me please…
this is my camera setting for RX100 M3…
Nihal
(Nihal M)
May 30, 2017, 7:30am
2
The parameters you’ve set for the camera are correct. The grid spacing and time estimate depend on the altitude and overlaps. What have you set them to? You can try to fine-tune the flight path to your requirements in that panel. Changing the camera parameters won’t help you.
aidil
(suriyadil)
May 31, 2017, 4:10am
3
tq for respond.
i’ve set for overlap and altitude, it change the grid but still make my plane overshoot far from the waypoint.
how to fine tune flight path?
Nihal
(Nihal M)
May 31, 2017, 5:33am
4
The tuning pages are well documented - http://ardupilot.org/plane/docs/tuning-quickstart.html . Go through all the tuning processes completely. Proper Navigation tuning - http://ardupilot.org/plane/docs/navigation-tuning.html will help you achieve proper flight paths.
