Any help with building ArduPilot on OSX fro px4-v2?
Following build with Make on OSX http://ardupilot.org/dev/docs/building-px4-with-make-on-mac.html
and then adding
brew install make alias waf="$PWD/modules/waf/waf-light" waf configure --board=px4-v2 waf --targets bin/arducopter-quad
the build failed building MAVLink
Waf: Leaving directory `/Users/bonney/dev_src/ardupilot/build/px4-v2â
Build failed
-> task in âpx4_msg_genâ failed (exit status 2):
{task 4430014256: cmake_build_task -> }
[â/usr/local/bin/cmakeâ, ââbuildâ, â/Users/bonney/dev_src/ardupilot/build/px4-v2/modules/PX4Firmwareâ, ââtargetâ, âmsg_genâ]
Output from war
bonney@MacVan:ardupilot (master)$ waf configure --board=px4-v2
Setting top to : /Users/bonney/dev_src/ardupilot
Setting out to : /Users/bonney/dev_src/ardupilot/build
Autoconfiguration : enabled
Setting board to : px4-v2
Using toolchain : arm-none-eabi
Checking for 'clang++' (C++ compiler) : /usr/bin/clang++
Checking for 'clang' (C compiler) : /usr/bin/clang
Checking for HAVE_CMATH_ISFINITE : no
Checking for HAVE_CMATH_ISINF : no
Checking for HAVE_CMATH_ISNAN : no
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : no
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : no
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : no
Checking for header endian.h : not found
Checking for header byteswap.h : not found
Checking for program 'cmake' : /usr/local/bin/cmake
Checking cmake version : 3.6.1
Checking for program 'ninja, ninja-build' : not found
Checking for program 'cp' : /bin/cp
Checking for program 'python' : /usr/bin/python
Checking for python version >= 2.7.0 : 2.7.10
Source is git repository : yes
Update submodules : yes
Checking for program 'git' : /usr/local/bin/git
Gtest : PX4 boards currently don't support compiling gtest
Checking for program 'arm-none-eabi-size' : /usr/local/bin/arm-none-eabi-size
Benchmarks : disabled
Unit tests : disabled
'configure' finished successfully (0.830s)
