Hey, I’m not having much luck getting this thing going. I keep having issues imaging the sd card on my ubuntu box so I switched to imaging the sd on windows. I think I finally got a good debian install but now I’m having problems with waf erroring during the build. I’m building it on the bbb.
Here is what it is giving me:
debian@beaglebone:~/ardupilot$ waf
Waf: Entering directory `/home/debian/ardupilot/build/bbbmini’
[3/4] Processing modules/mavlink/message_definitions/v1.0/ardupilotmega.xml
Traceback (most recent call last):
File “/home/debian/ardupilot/modules/mavlink/pymavlink/tools/mavgen.py”, line 16, in
from pymavlink.generator import mavgen
File “/home/debian/ardupilot/modules/mavlink/pymavlink/generator/mavgen.py”, line 12, in
from future import standard_library
ImportError: No module named future
mavgen returned 1 error code
Waf: Leaving directory `/home/debian/ardupilot/build/bbbmini’
Build failed
-> task in ‘mavlink’ failed (exit status 1):
{task 3060127784L: mavgen ardupilotmega.xml -> }
debian@beaglebone:~/ardupilot$ ./waf configure --board=bbbmini
Setting top to : /home/debian/ardupilot
Setting out to : /home/debian/ardupilot/build
Autoconfiguration : enabled
Setting board to : bbbmini
Checking for program ‘arm-linux-gnueabihf-ar’ : /usr/bin/arm-linux-gnueabihf-ar
Using toolchain : arm-linux-gnueabihf
Checking for ‘g++’ (C++ compiler) : /usr/bin/arm-linux-gnueabihf-g++
Checking for ‘gcc’ (C compiler) : /usr/bin/arm-linux-gnueabihf-gcc
Checking for program ‘arm-linux-gnueabihf-pkg-config’ : /usr/bin/arm-linux-gnueabihf-pkg-config
Checking for need to link with librt : not necessary
Checking for ‘lttng-ust’ : yes
Checking for library dl : yes
Checking for ‘libiio’ : not found
Checking for HAVE_CMATH_ISFINITE : yes
Checking for HAVE_CMATH_ISINF : yes
Checking for HAVE_CMATH_ISNAN : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : no
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : no
Checking for header endian.h : yes
Checking for header byteswap.h : yes
Checking for program ‘python’ : /usr/bin/python
Checking for python version >= 2.7.0 : 2.7.9
Source is git repository : yes
Update submodules : yes
Checking for program ‘git’ : /usr/bin/git
Checking for program ‘arm-linux-gnueabihf-size’ : /usr/bin/arm-linux-gnueabihf-size
Benchmarks : disabled
Unit tests : enabled
’configure’ finished successfully (10.394s)
Which instructions were you following which omitted the “install lxml and
future” steps?
