Ardurover don't run both engines
First you must see this my movie:
Movie
In manual mode everything works ok.
In autonomous mode is problem with engines.
Boat floats along the right lines, but never run both engines.
On the some times works only one engine as you see on movie.
I’m using Pixhawk 2.8 , and ardurower 3.1.beta4 software.
Any suggestions?
What is a Pixhawk 2.8 exactly? Is that STM32 32bit based hardware or APM style 8bit hardware?
To diagnose we need a log file and a LOT more details. Can you operate the boat in Steering mode? I assume your trying to use skid steering? What output channels do you have your motors connected to?
Thanks, Grant.
gmorph you are right. My mistake. Correct symbol is 2.4.8
I’m don’t tested Steering mode. How it works on boat?
Yes, i’m using skid steering, and in manual mode everything works correctly.
Steering mode runs the same software as Auto mode so you can use it to drive the boat and ensure turning left/right is correct.
A dataflash log would be helpful.
Thanks, Grant.
This is log file 172.BIN.zip (1.9 MB)
It’s graph how it works:
I think this is related to a bug I’m trying to fix at the moment. I hope to have a new beta release out soon with a fix.
Thanks, Grant.
