Hi. I’m trying to work out how the AP on the Edison is setup within the APSync build. i need to change this to not be a AP rather for the Edison to connect to an AP.
I thought Hostapd and dhcp server were used but I see no config files to edit.
Could somebody please tell me how this is setup.
Best Regards Anthony
I’m also in the same boat. You have to disable NetworkManager in order to use /etc/network/interfaces
Thanks, I will have a go at this.
