Hi, I have just tried the App sync download logs app and its giving the following error
Unable to locate /Home/User/DFlogs folder
any suggestions, Im using latest Apsync image with PH2.1
Hi Mad_angler1 did you get a fix for this? I would be very interested to know as I am getting the same error. I have re-flashed the edison twice, connected by SSH and confirmed that the edison is working and that logs are present using the "find " command (have confirmed they are present) but still no joy in being able to download them.
I had the same issue, There is a small error in the way the "apsync-download-logs-to-here.bat is put together.
Open the .bat file and replace the content with this.
pscp.exe -pw apsync apsync@10.0.1.128:dflogger/dataflash/*.BIN .
pause
Make sure that pscp.exe is in the same location as the .bat file that should work.
However, I found it much more convenient to use winSCP to access the log files. so you might want to try that instead.
