im new to the apm and i just cant figure this out.
i connected everything correct and motor direction is correct too. /but when i try to take off it arms spins the motors and the throttle reacts, but thats it…
I have no reaction on movement and other inputs. in mission planner i can see that the gyro and accelerometer are working. But it just wont response. does anyone have and idea on how to fix this. its driving me crazy…
Are the leds flashing correctly?
Do you get the boot up led sequence?
When you arm do you get the red/blue flash as the ground start occurs?
Have you armed it while connected to your GCS?
Whenever I have had strange things happen I reload the firmware onto the FC.
Maybe even total erase by loading plane then reloading copter.
This has, in 99% of cases, solved the issue.
