Hi!
I have a few questions regarding how the throttle and airspeed is handled in the different flight modes.
Important info: I am using a airspeed sensor.
I see that in FBWB, the throttle stick on the radio is actually controlling the throttle between
ARSPD_FBW_MIN
andARSPD_FBW_MAX
. The throttle output from FC to ESC is limited byTHR_MAX
Correct? -
THR_MAX
is by default at 75%, by increasing it to 100% the plane becomes more capable of handling headwind, what is the negative consequence of increasing it? -
How is throttle and airspeed handled in CRUICE? Same as FBWB with the additional adjustments based on changes in desired altitude by the elevator stick?
What is the target airspeed in AUTO? Is it
TRIM_ARSPD_CM
? If throttle stick is kept at 50% the target airspeed is set toTRIM_ARSPD_CM
Is throttle nudge accumulative, such as altitude adjustments in copter, or is the range between 50% and 100% defined as the range from
TRIM_ARSPD_CM
toARSPD_FBW_MAX
(and similarly 0% to 50% throttle corresponds to the range fromARSPD_FBW_MIN
toTRIM_ARSPD_CM
Does RTL use
TRIM_ARSPD_CM
as target airspeed? -
What about LOITER, CIRCLE and GUIDED?
What is
TRIM_THROTTLE
Thanks a lot for all answers.
