Hi Bill. You have explained it as I have experienced my weight increase of the TR700. But I hope there is a light at the end of the tunnel. Elon Musk,s batteries. I am in a process to work out if those TITAN Li-Ion packs are suitable for my application. That would reduce the Lipo Battery weight of my TR700 by half. Now 3.4 kg total of all Lipos on board. If it works with the TITAN Li-Ion the TR700 will weight 7.55Kg instead 9.25Kg with the heaviest of my cameras on board. Hopefully we have better battery options on the market soon.
Hi Markus.
The RJX has a Scorpion SII 3008 1220KV. Shaft replaced with a 6mm main shaft from a TR450 Heli. The TR700 has a Scorpion HK 4015 - 1450 KV. Shaft replaced with a 8mm main shaft of the RJX 500. This shaft is reduced to 6mm on a Leith to fit the Align tail pitch slider. I have tried all sorts of options different motors, coupling the shafts. It just does.t work without having a long one peace shaft with the pitch slider fitting on it. I have tried even a long titanium shaft because there is not a 6mm long enough shaft around as a spare from all models spare parts . You do not have a lot of motor options because of the shaft problem. Than you have to play around with the Lipos to get the right motor rpm. Here are the Castle Heli ESC.s the best option I believe.
The result for the RJX is that I am using for the tail motor a 3S 3300mAh battery. Don,t forget the COG has changed you might have to use a heavier Battery what you would like.
The result for the TR700 tail motor is a 2S 8000mAh battery.
The RJX has plenty left for a second flight. The TR700 has the same discharged as the 12S Main motor batteries.
There is so much involved it took me month between the change and flying again. But I am patient and take my time. I would not fly with the TR700 what I have not tried with the RJX 520. My RJX 500 had a crash because the motor cable connection from the ESC came unplugged in flight. Since than I do not use plugs to the tail motor any-more. The cables are soldered on and hidden in the tail boom. I do not have a 3 blade head for the RJX.
It is definitely not a simple change and should be considered very carefully. But I love the final result now with both Helis.
Hi Markus
Here is my params file i could get the heli off the ground but the delay on response was woeful so i did not do a lot more the thought is best for you to have a look at these files.
Cheers
Kevin
markus first flight param list.param (9.2 KB)
Hi Kevin,
some settings are not as usual, therefore please try this:
setup your TX with a Dual rate switch, low = 50% high=100%, Expo about 30% or whatever you like.
check Radio Calibration using high rates, left and right o.k., nose down gives lower numbers, collective up gives higher numbers, endpoints reasonable …
for early testing setup your mode switch for Acro, Stabilize and AltHold. Later you can change to PosHold, RTL, etc.
set STB_PIT = 4.5 and STB_RLL = 4.5 (back to default) play with these values later.
do the following setup in Acro mode, ACRO_TRAINER = 0 and high=100% rates on your TX, UNPLUG the motor and arm the heli (you need servo output)
you are using RATE_PIT_I = 0 and RATE_RLL_I = 0, that doesn’t really work for flying ! But now you want to make your setup, therefore keep this setting and set RATE_PIT_P = 0 and RATE_RLL_P = 0 and keep RATE_PIT_D = 0 and RATE_RLL_D = 0.
Set RATE_PIT_FF = 0 and RATE_RLL_FF = 0. Now if you move your cyclic stick(s) nothing happens (yaw should work)
The P-part + the I-part + D-part + FF-part = 0 therefore no movement.
The FF-parameter is the direct pilot input (no control loop feedback, therefore no oscillations). Depending on your taste you can put more weight on the PID-loop or more on the direct pilot input.
I prefer to fly RC_FEEL = 100 and use more weight on the pilot input part.
To do this raise your RATE_PIT_FF and RATE_RLL_FF until you measure more than +/-8° on the blades. Now lower H_CYC_MAX to get 6° to 8° depending on your taste.
Now lower RATE_PIT_FF and RATE_RLL_FF until you measure about 75% (or less depending on your taste) of this value, which would be 4.5° to 6°.
You should have now a reasonable swash movement (you are in helis since 35 years, you know how it should look)
Set RATE_PIT_P = 0.02 and RATE_RLL_P = 0.02 and RATE_PIT_I = 0.5 and RATE_RLL_I = 0.5 (P and I on default) and keep RATE_PIT_D = 0 and RATE_RLL_D = 0 -
your H_COL_MAX = 1650 and H_COL_MIN = 1400 doesn’t look right to me. Check your collective range, it should be at least +/-10°, I use +/-12°. In case your tail can’t hold the +/-12°, go lower, but not less then +/-10°. It would be better to get longer or more blades on the tail, as low rpm flying usually needs it anyhow.
you didn’t setup the tail limits ? They are still on default, please check.
check stick direction and move heli around all axis to check for correct counter action
use low dual rate setting and carefully try the heli in Acro mode, ACRO_TRAINER = 0. If not enough control, try high dual rate. In case the heli oscillates try ACCEL_Z_P = 0.3
The heli should be flyable now, far from perfect, but no severe problem. -
in Acro mode, ACRO_TRAINER = 0, if everything seems o.k., start channel 6 tuning. Start with TUNE = 4 and set reasonable limits. Watch out if you use Extended Tuning page, it might change some settings. Be careful tuning I, be very careful tuning P and be VERY, VERY careful tuning D parameters.
Keep in mind that the heli is sensible to air density. If you tune the heli in cold air at sea level to the limit, it will oscillate like hell in warm air on a mountain.
If Acro mode, ACRO_TRAINER = 0 setup is perfect for you, check Stabilize stick movements and counter action.
Kevin,
I think part of the reason why the response feels delayed is due to the large deadzone in the pitch and roll. I know I found that to be troublesome especially flying in acro. I suggest you set RC1_DZ and RC2_DZ to 5 or less. I think mine is set to 2. The exponential will then help provide a more shallow gradient initially.
Here is a nice article about PID: SAS_MHWJUN13_daves.pdf (1.5 MB)
RCx_DZ compensates for inaccuracy of your TX and RX channels. If you have the same trim value in hot and cold wheather you should lower it a lot. If it is too low it will be like constant input and confuse the PID loop.
RCxDZ = 30 and a sensitive setup will feel like nothing is happening around the center and usually the pilot is overcompensating.
Using a modern quality receiver RCxDZ = 5 should be no problem.
Hi Markus
Firstly thanks for all your help it is really very much appreciated
Not sure on what you mean “Start with TUNE = 4 and set reasonable limits”
i have adjusted all prams as suggested going to have a hover in the morning
Pitch range now 11.9 +/-
swash is 5.5 degrees
The tail did not need any adjustment from default it was perfect travel and center amazing but i had to have win some where.
have attached the current Param file for you to have a look at if you get time .
Markus params 111216.param (9.2 KB)
Cheers
Kevin
Hi Bill
I have adjusted those DZ to 5 so hopefully with the hover in the morning all will be OK fingers crossed
Starting to get a small understanding of whats going on in the FC and how it all works.
Big thanks to all the you guys in the forum and your valuable advise
Cheers
Kevin
Hi Kevin,
there are only two parameters changed compared to your last file, RATE_PIT_P and RATE_RLL_P back to default. Either you sended me a wrong file or my bad English is the problem or you think you changed parameters, but you didn’t really do it.
No, DZ is still at 30 in your file ! Go to ‘Full Parameter List’, type RC1_DZ in the ‘Search’ field and change the value to 5 AND click ‘Write Params’, now click ‘Refresh Params’ and check if you have 5. Same for the other parameters (you can change many parameters and save them with one click on ‘Write Params’.
DO NOT FLY using this setup !
Hi Markus
Thanks for that i spent hours changing it all but it has not save to the FC sorry for that ill do it all again in the morning and get back to you thank you for checking once again
Best Regards Kevin
In ‘Full Parameter List’ go to TUNE and set it = 4 to do channel 6 tuning on RATE_PIT_P and RATE_RLL_P. The default value is 0.020. You take the default value for the lower border, that is TUNE_LOW = 20 (1 = 1000, 0.1 = 100, 0.01 = 10, 0.001 = 1). Depending on the sensitivity of your channel 6 knob and your patience you choose the upper limit i.e. 3 times higher, in this case 0.060, which translates to TUNE_HIGH = 60.
The USB plug isn’t made to last forever, it is much more comfortable to use the telemetry link.
Please understand that YOU have to check EVERYTHING, it is your heli not mine
No problem. I know it took a while for me to learn about the code and it’s settings. Sounds like Markus is getting you squared away.
Hi Markus
I know what I did wrong I compared the parameters file and did not uncheck the boxes so they all went back to the previous settings “forever learning” you do need to be so careful as it would b very easy to loose a Heli.
any way here is the new Params file
Markus params 121216.param (9.3 KB)
By the way where do you live im in Perth Western Australia
Cheers
Kevin
this is the most important lesson in heli flying
This parameter file is much better !
Some things to consider:
Did you set the swash limit to get something like 6° to 8° with full aileron or elevator ?
H_CYC_MAX,2500 … still on default, can be correct ofcourse, I am only asking
H_COL_MAX,1685
H_COL_MID,1505
H_COL_MIN,1315
In an ideal world you would use the full resolution. H_COL_MAX - H_COL_MID = 1750 - 1500 = 250 for the default values. In your case 1685 - 1505 = 180 and 1505 - 1315 = 190, which means you could shorten your servo arms to have more power and resolution. You should consider changing this now, because you have to do the whole tuning again if you change it later. No need to achieve exactly 250 but you are quite far off so please consider changing to another hole on the servo arms. If you change don’t forget H_CYC_MAX should be around 2500 as well, so find a good compromise !
According to Fred 3.4.3 is good, it is your choice if you want to upgrade now or later.
You didn’t setup Throttle Failsafe as you still have FS_THR_ENABLE,0 and FS_THR_VALUE,975. It is up to you, but I strongly recommend to get a working Failsafe !!! Check it without blades by walking around with your heli as you have different behaviour in different modes. I know it is lots of work, but the devil never sleeps !
Some minor stuff:
Set RC_FEEL_RP = 100 if you like precise control, set RC_SPEED to the max. Hz your slowest servo can safely handle (tail servos are usually faster than swash servos). You should start in Acro mode and have Stabilize and AltHold for testing. Use GPS modes after you verified AltHold.
You should be ready for test flying after doing your homework
ALWAYS check stick movement and reaction to heli movements before EVERY flight !
I live on the other side in the ‘other Australia’ without kangaroos.
Hi Markus
I take it that your in NZ lovely place been a couple of times to commission and test fly new Rotorway 162 and Talon 600ARL Helicopters.
I had not reset the H_CYC_MAX but have done so now.
Not sure on how the fail safe should be setup?
I cant shorten the arms any more or they will push the swash from about 80 Degress instead of 90 you can see from the photos.
Hi Kevin,
There is quite a lot of info on Failsafe in the wiki. Please read first.
Arm the heli without blades, set the headspeed very low and check what happens when you switch your TX off, what happens if you pull the cable from RCin, etc. The behaviour is different depending on the flight mode, therefore my recommendation to walk with the heli away to check for RTL etc.
Yes you can, because swash movement and resolution is more important than 80° or 90°. You should set it up as described in the previous posting and watch for binding in the extreme positions.
Hi Markus
Thank you for your help got the FS working as it does in the wiki with the Taranis X9E FS no signal settings on the receiver.
Have shorten the arms and will upgrade the FW and compare the Param files after install.
Had a hover for 90 seconds all good totally controllable and a good start so now i need to get my old head around the tuning what am i trying to achieve with my low and high tune CH6 settings any thing i need to look out for before i start turning the knob.
The Yaw its really dead in the center as well do i change the DZ settings in RC4 or is their another menu for the tail settings.
Params 131216.param (9.3 KB)
Cheers
Kevin
I am sure it is not impertinent if I tell you I would prefer the Rotorway heli with HOGE 9000 feet instead of the beer
No signal setting is perfect.
You can change RC3_DZ and RC4_DZ to 5 as well.
Tuning:
Read the article in post #34. You should hover at 1m and have a finger on the throttle cut when you turn the channel 6 knob up (or be fast enough to turn it down).
General rule: Good judgement comes from experience and experience comes from bad judgement.
In other words you need to turn the knob until the heli starts shaking and back it off again 20 to 30%.
You should try to shake the heli using rythmic inputs, because heli can be smooth in zero wind and go into resonance (=self destruction) if it is gusty, therefore always choose the lower PID value when in doubt… Doing this tells you how P, I and D oscillations look like. For the D use TUNE_LOW=0 and TUNE_HIGH=3, be warned it’s D like Devil.
Use the Dataflash logs to check for Vibration and DesRoll vs. Roll, etc.
Too low PID (not balanced) can oscillate as well, correct mechanical setup is very important etc., therefore it can become quite complex.
Some parameters have a different name in 3.4.3.
Cheap way to remove main and tail blade vibrations: http://forum.heliguy.com/dynamic-cog-und-static-main-blade-balancing-t71916.html
You can put masking tape on the blade in the CoG area and balance the blade on a sharp edge. The blade should not balance in 90° (what you would normally do), but be balanced in 45° and 135°. When in balance push the blade against the sharp edge to get a mark (depression) in the masking tape. This way you get good result for CoG.
Hi Guys Have not forgotten all help and the progress had to come to halt for while due to other commitments and Xmas but hope to get back into the flying soon
Merry Christmas and Happy New Year to all
