5 motor spin at 14% and except one at 15%
Hi all,
I’m building a hex F550. When performing motor test, 5 of my motor will start spin at 14% except one. The one only spin at 15%.
My question, is that normal or is it harmful? Please advice, thank you.
Regards,
Leslie
I will assume you have calibrated the ESC’s
1% is very little, and may not make any difference in flight.
There can be a lot of factors affecting the spin up of a motor, variances in the ESC, motor bearings or other forms of physical drag on the motor.
Your first flight test is the final answer to your question.
I have calibrated the ESC as per the page that you sent to me. I will try to take off today. Thanks for your help again.
Regards,
Leslie
